Ariens snowblower tire repair ?
Old 02-02-23, 03:24 PM
Hello,
I have an Ariens Classic 24 snowblower that is about 3 years old. The one tire has a slow leak and goes flat after a couple weeks. Was wondering if these have tubes in them that can be repaired similar to a bicycle tire and how hard is it to get the tire actual tube out. Thx
Old 02-03-23, 12:56 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Tubes or not you can Slime them to fix the leak!
Old 02-03-23, 02:50 AM
Received 1,267 Upvotes on 1,207 Posts
It looks like it might have a tube but not certain. I would just keep filling it for now but do a soapy water test in warmer weather to see where the leak is, as that might help show the issue. Personally, I'm going to remove and patch a tube; slime is not a solution.
Old 02-03-23, 03:51 AM
Received 295 Upvotes on 265 Posts
First you have to find the leak.
Could be a bad valve or a loose valve. This is the first thing I would check.
Could be a hole in the tire which you may be able to fix with a plug.
Could be a rim leak.
If it does not have a tube to patch you could probably install one.
Pilot Dane voted this post useful.
Old 02-03-23, 05:12 AM
B
Received 302 Upvotes on 267 Posts
The tires do not have tubes when shipped from the factory. In my opinion a tube is the best fix. Pick a tube that fits your tire diameter and width and has a schrader valve.
Old 02-03-23, 06:08 AM
Marq1's Avatar
​​​​​​​slime is not a solution
For a slow leak like this slime is a great product, I have a wheel borrow that would go flat in a week, 3 oz of slime installed 5 years ago and it's still holding air!
If that doesn't work then the hassle of installing a tube would be next!
Old 02-03-23, 07:44 AM
Received 35 Upvotes on 34 Posts
For that application I would use the Slime. I have it in everything on the farm. It works not only on the leak at hand but against future leaks.
