Tune up kit for ES-250
Old 02-05-23, 09:03 AM
I have an echo es-250 blower/vac.
The plug in the es-250 is a NGK BPM8Y plug. The below kit looks to have a WX L7T plug and gas filter also looks a bit bigger in the kit than what is used in the es-250
Does anyone know if the below kit can be used on the es-250? Description only list es-210?
https://www.amazon.com/13120507320-A...%2C157&sr=1-18
Old 02-06-23, 11:40 AM
cheese's Avatar
Received 119 Upvotes on 109 Posts
That's a chinese no name spark plug. I have no way to cross reference it to what it may be roughly equivalent to.
The large filter may not fit into the tank through the grommet opening. Some Echos have a large opening for the tank grommet and some have a small opening. I would look for one made for your model.
Old 02-07-23, 01:56 PM
The filter does fit into the tank? Will this work and not cause issues?
The seller of the kit said plug said it is a universal plug.
But did not answer if it would work in the es-250
Old 02-07-23, 05:24 PM
cheese's Avatar
If it fits in the hole, it will work as a filter.
Old 02-09-23, 05:07 AM
Yes it fits,,,but is almost twice the size of the original.
I may just order a spark plug that is recommended and skip the universal one?
Old 02-09-23, 04:49 PM
This is the original gas filter
Old 02-09-23, 07:57 PM
W
Received 40 Upvotes on 36 Posts
i would not use a universal plug unless I was broken down on a lonely road with a one cylinder engine....
Old 02-10-23, 01:28 PM
I got the same plug that is in the kit below and used it.
https://www.homedepot.com/p/ECHO-YOU...152Y/300434965
https://www.homedepot.com/p/ECHO-YOU...114Y/300434409
I also took the engine cover off to clean the cooling fins.
Had an issue getting back on and had to remove a screw from the carburetor and had to rotate it right a few degrees to get the engine cover to snap together at the handle. I had to reattach the throttle cable and linkage rod
When I started the blower, it started right up but it is running a lot faster at idle than before.
Should I take it apart and check the cable or adjust the idle down by using the below ?
3. Check idle speed and reset if necessary. If a tachometer is available, idle speed screw (A) should be set to the specifications found on “Specifications” Page of this manual. Turn idle screw (A) clockwise to increase idle speed; counter clockwise to decrease idle speed.
Old 02-10-23, 02:37 PM
W
Turn the screw until it idles where you like it first. If that doesn't work, THEN take it apart to give yourself more adjustment capability.
Old 02-11-23, 11:14 AM
Tried turning the screw counter clockwise on turn, idle is still running too high..
No affect with the screw
Old 02-11-23, 01:02 PM
cheese's Avatar
Back it out some more and if it backs away from the throttle lever and is no longer touching it but the idle speed is still too high, then you have another problem. Possibly linkage connection or cable routing.
