Tiller recoil rope
Old 10-18-23, 07:05 PM
Tiller recoil rope
I had to replace the starter clutch on my 8hp Wheel Horse tiller.
When I pull the rope, the starter works and the engine starts and the rope is withdrawn
But I noticed that the rope is loose and has no tension. Can be pulled very easily
Only when I turn the engine off will the rope then have the tension...and I can then pull on it and restart the engine.
Is it normal for the rope to have no tension after pulling on it and engine is running and get the tension back after the engine stops?
Thanks
Old 10-18-23, 11:42 PM
cheese's Avatar
Received 141 Upvotes on 130 Posts
The starter can't engage a running engine. If it did it would wrap the rope up so fast it would yank it violently out of your hand and pop the handle off of it with enough force to hurt you. I've had it happen. The resistance you feel with the engine off is you turning the engine. If the engine is already turning, there is nothing for the starter to do or engage to.
Old 10-21-23, 03:52 PM
Ok..
What you are saying is it should be loose after the engine is running and recoiled
After pulling the cord and engine kicking over., the rope seems liked it did not want to rewind and i had to coax it to wind up. Very loose
.I will have to check again
A
Old 10-21-23, 10:49 PM
cheese's Avatar
It should rewind quickly and sharply. If not, the rewind is not moving freely and/or the clutch is dragging.
Old 10-23-23, 09:36 AM
B
Received 289 Upvotes on 257 Posts
I would try increasing starter recoil spring tension with the rope fully recoiled.
sdodder voted this post useful.
Old 12-01-23, 11:47 AM
Finally got a video. I started the tiller a few times and the clutch seems to be working. the rope does rewind, but is loose after running. I don't recall if this is normal.
Below is a short video
https://youtube.com/shorts/JvszMPOI7...H4skTIU3vt0kBf
Old 12-01-23, 11:56 AM
XSleeper's Avatar
Received 1,900 Upvotes on 1,706 Posts
You need to take the starter shroud off, remove the spring and either retension the spring and rewind it, or get a new spring and rewind it.
Old 12-01-23, 12:47 PM
ok..
i could also get a new assembly?
Last edited by XSleeper; 12-01-23 at 01:42 PM. Reason: Please don't link to other diy YouTube videos
Old 12-01-23, 04:09 PM
Received 34 Upvotes on 33 Posts
What it's doing is normal. If you want more tension on the rope when it's running you can put another wind on the return spring, but it looks like you don't need to do anything.
Old 12-02-23, 02:01 AM
cheese's Avatar
What is it supposed to do? The clutch is disengaged because the engine is running. What can it turn? Nothing. This is how it worked since the day it was made.
