Non-yellowing clear coat for white outdoor furniture
Old 03-23-16, 03:42 PM
C
Question Non-yellowing clear coat for white outdoor furniture
I just built a wood bench for my front porch and plan to paint it with a white exterior paint. I was thinking of putting a protective top coat over it, but haven't had much experience with top coats. The only thing I've used in the past over white was the Minwax water-based poly, and that yellowed the heck out of the paint job.
Any suggestions on something else I should try?
Old 03-24-16, 03:01 AM
Received 627 Votes on 554 Posts
Are you sure it was water based poly? water based shouldn't have turned it yellow but an oil base would have. That said, if you use a decent exterior latex enamel you shouldn't need to apply a clear top coat.
Old 03-24-16, 08:12 AM
Received 1,155 Votes on 1,114 Posts
Latex paint and water based poly should not yellow. If either the paint or the poly was oil based, then I would expect yellowing.
I agree with Mark about using a quality exterior paint and skipping the top coat in the first place.
