Painting existing cabinets white, clear coat?
Old 06-13-16, 06:19 PM
I'm in the process of painting existing cabinets white with Benjamin Moore White Dove latex eggshell finish. For protection which clear coat should I use so it won't yellow? There isn't a lot of sun hitting the cabinets.
Thanks!
Old 06-14-16, 04:52 AM
Received 824 Upvotes on 722 Posts
Welcome to the forums Stacy!
While oil base whites will yellow - latex whites do not. Generally there is no need to apply a clear coating over enamel. If you want more shine - use a shinier latex enamel. If you insist on using a clear coat use a water based poly, oil base poly will immediately yellow the white and more so as time goes by.
