painting high-density fiberboard?
Old 08-23-16, 01:57 PM
sgull's Avatar
Received 11 Upvotes on 10 Posts
In my shop there is some shelving built, the shelf material being 1/8" thick high density fiberboard (HDF). It's rather stained up and ugly so was wanting to improve the appearance plus add a little protection to help with wipe-up cleanup a little. It's that pegboard material type board (minus the peg holes), and is apparently called high density fiberboard. I'm a little concerned about warpage if I was to prime and paint the shelves with regular latex like I've been considering. Any thoughts/tips would be appreciated on what might be a good approach/method to get these painted up decently without complications. I was googling a little but seems like most info mentions painting of MDF (different stuff) and not the HDF especially that like mine which is only 1/8" thick. thanks
Old 08-23-16, 02:24 PM
Received 755 Upvotes on 660 Posts
1/8" isn't thick enough for a shelf - is it a thicker shelf laminated with the HDF?
I'm not familiar with HDF but it sounds like it's similar [maybe the same] to masonite. It's usually best to oil prime it! The top coat can be latex, waterborne or oil base. Since it's a shop I'd suggest finishing with an oil base enamel as it will wear well and won't have objects stick to it like latex is prone to.
Old 08-23-16, 02:36 PM
sgull's Avatar
Yeah I think it is similar or maybe the same as what's also called masonite. It's only 1/8" thick, no not the lamination of a thicker shelf. The shelf mostly just holds lighter weight spray cans and objects and such, and the frame/structure itself is good supporting for the shelves. Okay so sounds like best to go with oil primer/paint to avoid any warpage, eh.
Old 08-23-16, 02:40 PM
1/8" isn't thick enough for a shelf! I'd rip it down and install something thicker
Old 08-23-16, 03:22 PM
sgull's Avatar
Naw it's just a little shelf for some lightweight stuff. It's fine for what its used for. Not gonna rip it down. Just wanted to inquire about the painting of it. And guess I'll go with oil primer/paint, per the advice, even though that's more trouble, takes longer to dry than latex would. Thanks
Old 08-23-16, 03:44 PM
If you want to use latex for a finish, you could use flat latex as it won't cause sticking .... but it will also mar easily. Waterborne enamels dry almost as hard as oil base enamels but they're kind of pricey
Old 08-23-16, 04:11 PM
sgull's Avatar
But would not the waterborne enamel possibly tend to cause warping of the thin material, as I'm thinking the latex possibly would?
Old 08-23-16, 04:17 PM
A good coat of oil base primer will protect the HDF from the moisture in both waterborne and latex paints.
Old 08-23-16, 04:38 PM
sgull's Avatar
Ah, okay will go with some oil base primer I have on hand, and also I have some "acrylic interior latex enamel" paints, various colors of which to choose. Cool. Thanks marksr, I think I'm good to go.
Old 08-24-16, 03:14 AM
Flat latex paint won't have a sticking issue but your latex enamel might although maybe you'll be ok since the shelf is so light it won't have anything heavy setting on the latex enamel.
Old 08-24-16, 08:25 AM
sgull's Avatar
Ok maybe not good to go, yet. Slightly confused now. Question time:
1, You said flat latex paint won't have a sticking issue but latex enamel might. Well then how about flat latex enamel?
2. I've been assuming since you mentioned it that a "waterborne" paint is the same as a water-based or latex paint. Apparently that is not the case, and a "waterborne" is some special and rather expensive paint formulation, different from regular water based paint (or latex)?
Old 08-24-16, 08:48 AM
Received 1,197 Upvotes on 1,152 Posts
1. Yes, this could have sticking issues
2. Yes, this is different than latex enamel
If not using white paint, oil based enamel would also be a choice (not white since oil based paints can yellow a bit with age)
Old 08-24-16, 09:01 AM
sgull's Avatar
hmm I have plenty of oil based enamel. And not white.
Guess I'll use that.
Old 08-24-16, 10:07 AM
Latex enamel will stick to the primer but the 'sticking' I'm referring to [also called blocking] is where an object set on top of the latex enamel for an extended time will stick to the paint. The cheaper the latex enamel is the more apt it is to stick. It doesn't matter a whole lot what sheen the enamel is. This issues isn't associated with flat latex paint.
An over simplification of water borne paints is it's a cross between latex and oil base.
IMO oil base white would be ok in this situation - who cares if the paint yellows on workshop shelves
Old 08-24-16, 10:27 AM
Someone neurotic like me
Old 08-24-16, 10:47 AM
sgull's Avatar
I have a whole gallon of old leftover oil base sort of beige color paint. Pittsburgh "chevron off-white industrial enamel". Probably overkill for my measly shelf but might as well use it.
Old 08-24-16, 11:08 AM
Sounds like a plan to me.
Old 08-24-16, 12:14 PM
sgull's Avatar
Whew. Good to go...
Thanks
Old 08-24-16, 01:07 PM
Ought to wear great
Old 08-24-16, 01:20 PM
sgull's Avatar
Good to hear. Industrial grade long wearing paint job for my rinky dink shelf. This'll be awesome.
  #21
Old 08-24-16, 01:36 PM
Overkill is my middle name.
Or is it Paranoia...?
Eh, depends on the situation
