Remodeling My Mobile Home
Received 0 Votes
Doing some remodeling and I have a few questions about the walls. Q1...How do I get the beige paint that is peeling smoothed out to paint over? I tried taking a piece of small grit sand paper to it and it just kept peeling away. Q2...I bought some good quality white paint with primer, when I paint over those different colors you see, will it all come out the same color? TIA!
Welcome to the forums.
You'll either need to link to an open picture hosting site or post to the board directly.
We cannot access your private Facebook account. http://www.doityourself.com/forum/el...-pictures.html
What is this a picture of? Do you have any that aren't close up? If it is a wall intersecting a floor, you will have base molding where the errant line is anyway, so smoothing it out and painting it may be a moot point.
Most mobile homes use 1/4" drywall with a printed vinyl face [instead of the normal paper face]
I'd lightly cut just beyond the peeled areas and scrape it up to that point, then apply a thin layer of joint compound to smooth out the transition. Once dry you should be able to sand, prime and paint. Primer/paint alone won't make that bad spots disappear although it would make it slightly less visible.
