How do remove paint on wood trims?
Old 12-21-16, 04:31 AM
C
Received 5 Upvotes on 5 Posts
What are some methods or solvents to remove paints that got on wood trims?
Old 12-21-16, 04:49 AM
Received 839 Upvotes on 736 Posts
What type of finish is on the wood trim? Denatured alcohol and products like 'goof off' and 'oops' will soften/remove latex paints. Sometimes the best method is to gingerly scrape off the errant paint.
Old 12-21-16, 05:22 AM
C
It just regular Dutch Boy water-based white paint.
Old 12-21-16, 05:31 AM
XSleeper's Avatar
Received 1,919 Upvotes on 1,723 Posts
What sort of finish was on the trim before you got paint on it.
Old 12-21-16, 06:47 AM
C
How many types of finish there are? I don't quite know but it was hard wood.
Old 12-21-16, 08:24 AM
Received 1,267 Upvotes on 1,207 Posts
Was the wood stained and finished with lacquer or polyurethane? Was it painted with oil based or latex paint? Those are some of the finishes you could have had.
Old 12-21-16, 08:32 AM
Are you trying to just remove errant paint or do you wish the strip the paint off of the wood?
Old 12-21-16, 08:38 AM
C
I don't know what the differences are but when I paint the wall there were some paints accidentally dropped on the trims and I just want to remove them.
Old 12-21-16, 08:52 AM
Often the best method is to gently scrape off the errant paint. If it mars the poly it can be touched up as needed - just don't get aggressive with the scraping. I usually use the edge of my pocket knife to scrape with.
Old 12-21-16, 10:02 AM
XSleeper's Avatar
Try some Goof-Off on a clean rag.
Old 12-21-16, 10:19 AM
If you use goof off or similar you need to be careful not to get it on the wall or it will remove that paint too.
Old 12-21-16, 10:50 AM
C
Thank you guys for all the tips.
