Refinishing rusty metal furniture
I've some flowers medal vases in the back yard. How do I remove the rust? Will I put something before painting it? What kind of paint do you like or use?
First you need to clean the rusted areas down to bare, shiny metal. Sandpaper or a wire brush can be used and the most difficult will be getting into the nooks and crannies around the welds.
Old black medal flowers vases
I've 3 metal black flower vases in the back yard. How do I remove the black paint? Do I use mineral spirits and the bristle or use the sandpaper if so which sandpaper do I use? Thanks
I tend to sand to remove paint from metal. Depends on the actual metal but 40 grit paper is not out of the realm of possibility.
