Finishing Wainscotting
Received 0 Votes
I just love, Wainscot around the house; and when I did a little research...it didn't seem, like the most complicated DIY to tackle.
I based my work, off a video; which I may not be able to refer to here.
I have to say: to an extent...I was rather pleased, with my results.
Don't laugh
I mean, at this point; I was really pretty encouraged. This was the design I wanted; and it seemed like the finishing touches, were just a matter...of simple formality.
And now, is where you all start laughing; because as I've learned...those are the parts, that differentiate an "amateur" job from a "professional" one.
So...the project, lies stuck; here...
At this point; I have 2 main problems...that I know of...to tackle:
1) My carpentry work, was not super accurate. So while they weren't HUGE; I did have some gaps in my boards, that needed compound. My though-process? Go heavy...make sure you fill the gaps; you can always sand-down, to a nice finish. Ugh...I found out, not so much. This stuff (and I don't even remember, what I used at this point. I'm sure I can find it; but probably DAP spackling compound); kinda a b*tch, to sand down.
Hand sanding wasn't doing the trick. Checking it, as I'm posting; it seems like it's not in as bad as shape, as I thought; after I took a Palm Sander to it.
So...if I think it's smooth and seamless enough; do I just go for it. Clean, prime, and paint; cross my fingers, and hope for the best?
Issue 2, in next post. I think I need to take some pix for that...lol
Don't laugh
Last edited by Shadeladie; 07-29-17 at 10:11 AM. Reason: Removed non beneficial comments
Part of the problem is to many words. Just a couple of paragraphs to ask your questions and pictures at the bottom would have been better.
I'll move your thread to Painting & Staining and see if you get more replies.
Received 0 Votes
Sorry. 1st post; lots of background. Plus...I warned I was "meticulous"; but maybe that got edited out, by the mods.
I have to admit; I've never been truncated before.
In my experience...part of the process, of welcoming in a newbie; is to draw pertinent info out of him. If I knew what was what; I wouldn't have so many questions, and be here in the first place...right?
Received 0 Votes
I would think...like a lot of weekend warrior amateurs; I've gotten myself, into a pretty common situation.
Knew how to start; not sure how to finish.
So...if you want me to cut to the chase: how do I finish this??
Caulking tips:
While painter's putty is traditional for nail holes you can use your finger to dab on a bit of caulk then wipe smooth with a damp sponge or paper towel. Save any excess scraped off with a putty knife on a board and dab the nail holes before it sets up.
If the wood does need touch up sanding to smooth it do before caulking.
*When using a putty knife drag it, don't push it.
- Use acrylic latex caulk.
- Do NOT use oil based caulk. It is too hard to work with.
- Do Not use pure silicone caulk. Can't be painted. Harder to get a neat job.
- Have a bucket of water and a sponge or good quality papers towels ready when you caulk. (Cheap paper towels won't work well)
- You do not sand caulk. Apply, let set for a few minutes, scrape off excess with a putty knife*, then smooth and remove remaining excess with a damp sponge or paper towel rinsing often.
- If you want you can put painter's tape on either side of where you caulk. Smooth with sponge. Let set and remove the painter's tape.
I'd recommend using a siliconized acrylic latex caulk, it's a little better than just acyrlic latex and is paintable. While I prefer a damp sponge, a damp rag also works well - never tried a paper towel.
The caulk should either be applied prior to priming [let the caulk set up first] or between the primer and finish coat after it's been sanded.
Mark wrote:
Mark's the painter, I'm the wood butcher so follow his recommendation on caulk. Siliconized is good just don't confuse it with pure silicone. That you do not want.
Received 0 Votes
Sorry guys. After all that; it may have been for naught.
When I went to have a closer look (project has been sitting dormant, for months); I guess I did get it down smooth and paintable...and just didn't think so.
So...started painting; but don't worry. I'll have some questions, about trim and "finish"; or will that, have to be posted elsewhere?
Did you caulk the joints? they often become more visible once paint is applied. Generally it's best to keep a related thread together, that way those of us with a poor memory [me
] don't have to jump around to keep up.
Received 0 Votes
Yeah; I'd prefer to keep it together; but you guys seem pretty strict, about staying on topic.
When I go from painting, to trim to give it a finished look; will it be OK, to leave it here?
