Which first
Which first
Redoing a bedroom, sheetrock is all done, spackled and primed. We are installing stained pine door jambs, molding , and trim. Do we do trim first, caulk and then paint, or paint first then install molding and trim? I was told by a contractor to do trim and caulk first so any gaps are filled and cutting in can be done right up to moldings. I realise that a lot of cutting in will need to be done this way but I'm not doing the painting myself. Lol
If you have the option, definitely paint first, trim later. If the trim was painted it would be a completely different story because the trim would be caulked to the wall. Stained trim is not caulked to the wall.
All molding and trim is installed, stained and varnished, or what every method is being used.
After it is well dried, you mask it off then paint the ceiling,
After ceiling is dry you paint the walls,
Remove tape and caulk a small bead along the edges of the trim against the painted wall with a caulk the color of the wall to hide any small gap or paint edge.
Then stand back and enjoy a perfect room paint job!
