Painting Kitchen Cabinets
Old 10-04-18, 07:07 PM
T
Hello, looking for some recommendations on painting or refinishing kitchen cabinets. The cabinets are original oak and the finish is very rough. The floors are being refinished to a dark walnut so I have been leaning towards painting them white. I have looked all around online and YouTube and have gotten a lot of different options. I’m looking for durability as I have a 1 year old, another on the way, and two dogs. I have watched videos of people deglossing, stripping, sanding and also people using gel coat paints. I have an airless sprayer so I am planning on using that to prime and paint them.I am unsure of the process and products to use prior to painting to ensure a good long lasting finish. Any recommendations of how to go about this would be greatly appreciated! Thanks!
Old 10-05-18, 02:33 AM
Received 741 Upvotes on 647 Posts
Personally I'd only spray them if I removed them to a remote area. Overspray can/will travel a long ways. You'd need to cover and seal off the room including HVAC vents.
The Ideal Cabinet Repaint
In a nutshell - you need to clean, sand lightly and use a solvent based primer to insure good adhesion over the cabinet's finish. Oil base enamels are the most durable but whites will yellow over time. Waterborne comes in a close second and doesn't yellow. Latex enamels are ok if you use a quality one, the cheaper ones are prone to chip/peel.
Old 10-05-18, 04:46 AM
XSleeper's Avatar
Received 1,714 Upvotes on 1,538 Posts
White pigmented lacquer is also an option if you intend to mask and spray.
Old 10-05-18, 06:22 PM
T
Yes I am planning on taping off everything including the floors. These will be sprayed before the walls get done. Thanks for the link to the cabinet painting page!
Old 12-01-18, 06:11 PM
C
I use extreme bonding primer from sherwin williams and pro classic for the finish. You can set up a spray booth for the doors and hand brush the finish on the boxes. It lays down smooth enough.
