Lacquer not drying
Old 11-05-18, 10:02 AM
L
Lacquer not drying
Hi there, I'm new here, hope I post this right. I purchased a small box from Michaels which I sealed with shellac and then painted over with several coats of rustoleum fast drying white gloss lacquer. I don't live in a hugely humid climate but the paint is not drying very well, probably because I sprayed it on a bit too thick to get the smooth texture I was after. I handled it after a week and a few small indentations got into the paint as well, proving further that the paint just isn't settling. I'd like to ask advice on what I can do to help it dry, and what can I do to get those small indentations out (obviously before it dries). I tried putting it in the bathroom with the shower running in the hopes that the steam would get the paint to smooth out a little, but it didn't work.
Pictures: https://drive.google.com/open?id=1S6...J7rWxMIObsJLLq
Old 11-05-18, 10:31 AM
XSleeper's Avatar
Received 1,721 Upvotes on 1,545 Posts
if you didn't stir the goop up off the bottom of the can and mix it well, that's why its not drying. or there is a reaction with the shellac. only dewaxed shellac should be used as a sealer for lacquer. Or you put way to heavy of a coat on. You don't apply finishes thicker than what is recommended. It affects the way the finish dries. If it doesn't dry, you should chemically strip it and start over.
