Painting Concrete Block Wall
Old 04-15-19, 02:02 PM
WRDIY's Avatar
Received 41 Upvotes on 39 Posts
Hi,
My next door neighbor hired a contractor to paint his side of our concrete wall (sharing) last year. The final result is very smooth and I like it. While the contractor was doing it, I was watching. He pressure washed the walls and then he sprayed the wall with about 2 coats of paint. I think they did the entire job (around the house) in a total of 3-4 hours, including cleaning the wall too. I have asked my neighbor if the contractor used a self leveler or some type of filler? He does not know.
How can achieve the same smooth result without mortar grid lines? I would like to do it by rollers since I don't have an air compressor for painting.
Thanks
Old 04-15-19, 02:05 PM
Received 850 Upvotes on 746 Posts
Is this a block wall or poured concrete wall?
Even when spraying it's best to back roll the paint.
Assuming you meant block wall I know of no paint that will hide the mortar joints although they could be filled in with stucco. I normally roll on a coat of block fill [fills the pours and primes the block] and then a coat of decent latex house paint.
Old 04-16-19, 01:24 PM
WRDIY's Avatar
Hi MarkSR,
Yes, it is a Cinder Block Wall similar to these: https://images.search.yahoo.com/sear...v-web&fr=crmas
Would you be able to recommend a block filler that I can buy from Home Depot?
Old 04-16-19, 01:28 PM
WRDIY's Avatar
Would staining be easier than painting? Just a thought.
https://i.pinimg.com/736x/08/00/bf/0...93e01a3cdf.jpg
Old 04-16-19, 01:37 PM
WRDIY's Avatar
You are awesome as always Mark! Thanks!
Off to Home Depot.
