Repainting truck box
Received 0 Votes
I am repainting my truck box with a bed liner and the instructions said to sand it and then use acetone to clean it before I apply the liner. But the acetone seems to be undoing the dull finish that was done with the sand paper. What am I missing, thanks
Your following the instructions so Im not sure what the problem is?
The solvent is removing the sanding dust but the sanding scratches are still there. That is what you want - a clean scuffed up surface so the bedliner will adhere well. What grit sandpaper did you use?
Received 0 Votes
I used a 150 grit. And while I can still see some of the scratches after cleaning with the acetone a good amount are gone and the surface appears to have returned to its pre-sanding state which has a gloss to it. https://*******/gj13WQL
I have re-sanded a part about half way up the picture to show the difference.
150 grit should be ok although a lot depends on how thoroughly you sanded.
your pic link doesn't work - https://www.doityourself.com/forum/e...-pictures.html
