Painting lacquered oak?
Old 10-06-19, 10:04 AM
T
We have oak railings on our staircase. My wife wants to paint the spindles white.
I presume it is lacquered, but don't really know.
Does it have to be primed first, or just painted?
Old 10-06-19, 10:10 AM
Received 842 Upvotes on 739 Posts
Yes, you need to use a primer. If the staircase was site finished it's probably poly but at any rate the same method is used to paint them; sand lightly and apply 1 coat of a solvent based primer. You'll then need to 2 coats of your choice of latex enamel.
Old 10-06-19, 11:44 AM
T
Sanding is going to be tough with all the contours. How essential is it?
It is assembled, so I presume it is factory finished.
Old 10-07-19, 02:29 AM
It doesn't need to be a heavy duty sanding, just enough to scuff up the finish a little to promote good adhesion. Those sanding sponges work well on contoured surfaces.
