How to remove stucco from my walls?
Old 10-09-19, 08:51 AM
G
I want to remove the stucco off my bathroom walls. What is the best approach?
Old 10-09-19, 09:14 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
I assume you are referring to the inside walls?
A lot depends on what the material is, how the walls were, or were not prepped.
Id start with a stiff putty knife and maybe a hammer and go from there!
Old 10-09-19, 10:52 AM
P
Received 2,007 Upvotes on 1,799 Posts
Are you certain it's stucco and not lathe and plaster or sheetrock?
Old 10-09-19, 03:35 PM
Received 800 Upvotes on 703 Posts
If it's texture, scrape down what you can and then skim coat the wall.
Old 10-13-19, 06:49 PM
T
Received 44 Upvotes on 37 Posts
Stucco is Portland cement plaster. There are instances of this being used in bathrooms. I am guessing by stucco you refer to the texture rather than the material. Start by scraping what you can. It is usually easier to smooth over a rough texture than remove it. In a bathroom you should use a setting type of joint compound Durabond by USG is most durable but hardest to work with and nearly impossible to sand. So use a product like EasySand by USG it is a bit more amateur friendly and easier to sand. It might take more than one coat. When it is perfect (or good enough to suit you) then paint with a good paint that will withstand the moisture conditions in the bathroom. If you have real stucco, Portland cement plaster don't try to remove it. This is a can of worms best covered over.
