Removing acrylic paint from hardwood
Old 10-30-19, 08:47 AM
Nightfly's Avatar
We had hardwood stairs put into several months ago. I finally got around to painting the risers white. I used the blue tape but a lot of white paint leaked onto the wood. It is very difficult to get off. The stairs do not have the perfect gloss like a floor would. Without damaging the stair what is the best way to get the paint off? Heat gun?
Old 10-30-19, 08:58 AM
P
Received 2,272 Upvotes on 2,024 Posts
I would at as soon as possible before the paint can fully cure. I would first try a plastic scraper. If it tends to pull paint off the riser I would cut a shallow line with a box cutter between the tread and riser.
I would save heat as a last resort as you can't focus the heat only onto the paint that crept under your tape. Most of the heat will go to the tread and riser and risk loosening or bubbling them.
In the future... after putting down painters tape seal the edge well. I use a putty knife or piece of metal and firmly slide it along the edge of the tape where I will be painting to get that edge stuck down well. I don't touch the rest of the tape so it's easier to remove.
Old 10-30-19, 11:02 AM
Received 298 Upvotes on 268 Posts
Next time try Frog Tape.
Does a much better job sealing the edges than blue painters tape.
Old 10-30-19, 11:10 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Regardless of the tape, if you lather on large volumes of paint there is a chance it's going to leak.
A good technique to use it to lightly paint the edges with a relatively dry brush, that paint will form a seal from the tape to the painted surface.
When that dries put down your coat(s) of paint and you will have much less bleed through.
Use this and you can actually save a lot of $ by not buying the expensive tapes!
Old 10-30-19, 11:12 AM
Received 871 Upvotes on 762 Posts
Often the best way to remove dried paint like that is to carefully scrape it off with the edge of a sharp knife.
Old 10-30-19, 11:56 AM
Nightfly's Avatar
I saw frog tape at the paint store but I went on the cheap. I also was in a rush. Thanks
