Best way to prep stained trim work for painting
Old 11-03-19, 12:04 PM
B
I a have a LOT of trim that is stained and sealed with poly. We want to paint it white now. What is the easiest way to prep this before painting?
I have been told light sanding OR abrasive pad OR liquid sander etc. The trim has a fair amount of intricate contouring. Also, how do you do inside corners best?
Thanks for any tips!
Old 11-03-19, 12:54 PM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
It the poly glossy?
You need to scuff it up to a dull finish, the scotch brite pads will work good!
A coat of primer, then paint and you should be good!
Not sure what your asking about for inside corners!
Old 11-03-19, 01:19 PM
B
Thanks Marq1. I was just concerned about really getting into the corners to scuff them up.
Old 11-03-19, 03:28 PM
XSleeper's Avatar
Received 1,899 Upvotes on 1,705 Posts
Light scuff sanding then an oil based primer.
Old 11-04-19, 03:14 AM
Received 821 Upvotes on 720 Posts
I normally scuff sand, wipe down with a liquid deglosser and then apply a solvent based primer [oil or pigmented shellac] Expect to apply 1 coat primer and 2 coats finish. After the primer has dried and been sanded you should caulk all the joints.
