Finishing kitchen cabinets
Old 12-23-19, 05:47 AM
A
Received 73 Upvotes on 66 Posts
A buddy of mine is converting part of his home into a mother-in-law quarters, and found a deal on some unfinished “oak“ cabinets. I do not know if they are real or faux, but he thinks real. Anyway, he is looking for a relatively durable finish with little or no maintenance required. He asked me about this, and I am not a finish guy, so I gave him a couple of recommendations of places to check, but figured I’d ask here. I don’t know if, for example, something like ting oil is the right solution, or what. Again, a mother-in-law quarters, so not looking for a 20 to 30 year expectancy, and will probably use them for general storage in the garage once the current use is no longer needed. Thank you.
Old 12-23-19, 06:09 AM
Received 786 Upvotes on 689 Posts
Does he want to change the color? or just apply a durable finish? I'd stain [or not] and apply 3 coats of oil base poly [sanding between coats] Oil base poly will deepen the colors naturally in the wood and amber some as it ages. Water based polys just give it a clear with sheen but unless you go with the 2 part finishes they won't be near as durable.
Old 12-28-19, 02:10 AM
Received 1,231 Upvotes on 1,179 Posts
Mark beat me to it but three coats of oil based poly has been my go-to finish for a long time.
Old 12-28-19, 04:41 AM
Tolyn Ironhand's Avatar
Received 786 Upvotes on 666 Posts
I agree 100%. I finished my kitchen cabinets using oil-based poly and it still looks great.
Old 12-28-19, 05:20 AM
Marq1's Avatar
Received 1,209 Upvotes on 1,098 Posts
So I'm the decenter here, I have moved away from oil based products and years ago would not be recommending water based products but in the past 10 years I have had exceptional luck with furniture and cabinet projects using high end water based materials!
Do not associate these with krappy Min Wax products, they are not the same.
The line that was recommended to me by a furniture builder, and the only one that I have used, is General Finishes.
https://www.woodcraft.com/categories...5D=Water+Based
