Workshop shelves
Old 08-14-23, 08:03 AM
maarkr's Avatar
Received 23 Upvotes on 20 Posts
Workshop shelves
I have 3 24" deep storage shelves in my garage, abt 20' long ea. Made of OSB. I'm pretty'ing up the garage and my question is: should I use paint or cover them with non-adhesive shelf liner?
Old 08-14-23, 08:05 AM
P
Received 2,183 Upvotes on 1,953 Posts
It's a shelf. Do whatever you want unless I'm misunderstanding. My choice would be paint.
Old 08-14-23, 08:57 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Hopefully nothing heavy, OSB is not as strong as plywood for something like that,
Old 08-14-23, 09:20 AM
Received 840 Upvotes on 737 Posts
I'd probably just put a coat of poly on them to seal them.
C
Received 351 Upvotes on 294 Posts
I have OSB shelves under my workbenches. I covered them with 1/8" hardboard. Depending on the span of your shelves and what you are storing on them, you might consider supporting them with 2X4 frames.
Old 08-14-23, 11:52 AM
T
Received 110 Upvotes on 98 Posts
I like my workshop to look good but can think of many points I'd address before shelving as very little of it is visible.
Old 08-14-23, 05:06 PM
Tolyn Ironhand's Avatar
Received 878 Upvotes on 741 Posts
I also vote for a clear poly. Even OSB can look pretty nice with a couple of coats of clear poly. Just roll it on with a foam roller.
