safe to tape hot water pipes with painter's tape?
Old 02-12-24, 02:42 PM
I
Received 2 Upvotes on 1 Post
Hello,
I am painting the garage ceiling and there is a small network of plumbing pipes that i need to tape up. some of them have hot water flowing through them (from the hot water tank and the hot water heating system).
this might be silly question, but better safe than sorry - is it safe to tape these hot water pipes with painter's tape or can the heat cause any dangerous chemicals to get release?
thanks!
Top Answer
02-12-24, 03:50 PM
PJmax
PJmax is offline
Received 4,051 Upvotes on 3,634 Posts
Taping those pipes is not hazardous.
The only problem is that tape can be hard to be removed.
Old 02-12-24, 03:50 PM
Ialsomakesoap, marksr voted this post useful.
Old 02-12-24, 03:59 PM
B
Received 308 Upvotes on 273 Posts
Use foam pipe insulation for the mask.
Ialsomakesoap voted this post useful.
Old 02-13-24, 03:05 PM
I
thanks all! foam pipe insulation is a good idea for those pipes that aren't too close to the ceiling. i'll try that!
for the other pipes, i guess i'll have to block some time to remove the tape, but at least it's not hazardous.
thanks again!
