Quickest way to remove paint from exterior wood?
Old 03-12-24, 08:05 PM
R
Received 3 Upvotes on 2 Posts
Is there such a thing as a one-shot paint remover - i.e. one that goes through the paint down to the wood, one application without damaging the wood?
My typical method is to coat with paint remover, cover with plastic wrap, remove as much as will come off with a scraper and putty knife, repeat. It doesn't seem to matter if I use strippers with toxic solvents like methylene chloride or "green" strippers like CitriStrip - it still takes multiple passes.
Know any tricks to speed it up?
Thanks!
Old 03-13-24, 05:12 AM
P
Received 2,269 Upvotes on 2,021 Posts
"Is there such a thing as a one-shot paint remover - i.e. one that goes through the paint down to the wood, one application without damaging the wood?"
Sometimes, but generally no in my experience. It depends on the paint, how many coats and the stripper. Generally though I'd say it's a rarity. I've always had to do at least touch up on areas that weren't stripped and sometimes have to do multiple stripping coats..
RobertP voted this post useful.
Old 03-13-24, 06:04 AM
Received 870 Upvotes on 761 Posts
Why are you wanting/needing to remove the existing paint?
Old 03-13-24, 07:21 PM
R
Wood garage door, the old paint is tired, going down to bare wood with fresh paint.
Old 03-14-24, 04:03 AM
If you intend to paint [not a clear or translucent finish] All you need to do is scrape/sand it, no need to remove all the paint.
