Removing Built In Shelving
Hello - we are hoping to remove this build in shelving, just the paneling and keep the space for TV, etc. See pictures, what is the best way to remove the wood trim that is nailed to the drywall without damaging it too bad?
If the shelves are tacked down, knock them up and off of the cleats first. If you can tap a putty knife behind the 1x2, do that. Then drive a small prybar or glazing bar between the putty knife and the 1x2. The purpose of the putty knife is to protect the drywall... so that if you have to pry, you don't dent the wall.
Thanks, good tip! I've removed the 1x2's. It appears the flat shelf itself is actually stuck in fairly well. Tacked in on each side.
Before I cause myself any additional drywall repairs, I thought I would check if you had any advice. See photo.
