Tightening oil pan sump plug
Old 05-16-16, 07:15 AM
A
Question Tightening oil pan sump plug
Recently got my oil changed and have noticed the car is leaking a lot of oil, think it appears to be coming from the sump plug.
Do you guys think it's just simply tightening it a bit more, or is there possibly a washer or something that might be missing?
Have attached a pic, the plugs that I have seen before have had a male hex fitting, this one is round with a female head. What tool would I use to turn it?
Thanks (:
Old 05-16-16, 07:28 AM
P
Received 1,951 Upvotes on 1,747 Posts
It is possible you are missing the washer. Usually they are soft copper or aluminum. To tighten your plug you need an Allen wrench. They are available in ANSI (English) and Metric.
Old 05-16-16, 08:08 AM
F
Might also help to know what kind of vehicle you've got.
My Mustang and Explorer don't utilize a washer between the plug and pan, but I know there are many vehicles out there that do use a crush washer there, and a new one would typically need to be installed at each oil change.
Old 05-16-16, 08:21 AM
Received 3,600 Upvotes on 3,228 Posts
You may also be dealing with a stripped drain plug.
I wouldn't recommend trying to tighten it more. I'd take it back where the work was done since the oil will most likely need to be drained for the repair.
Old 05-16-16, 08:49 AM
A
Ok, I see. Thank you for everyone's advice. I'll try and call him tomorrow. The vehicle is a '68 E-type Jag..
Old 05-16-16, 09:27 AM
Received 785 Upvotes on 688 Posts
The main thing is was the drain plug leaking prior to the oil change? If it was, it's on you but if this is something totally new then the mechanic should take care of it free of charge.
Old 05-16-16, 11:12 AM
ukrbyk's Avatar
Received 50 Upvotes on 41 Posts
This is why I told my son not to buy a British car yet he did buy a Land Rover. Of course, leaking oil across entire power train from various spots.
OP, you need to get a real oil drain plug. Not that flimsy small head hex bolt. Oil drain plugs have wide flange head. Then you set a COPPER (don't do aluminum) washer under the head, and hand torque it. THAT will work just fine. Like this one here:
http://www.opieoils.co.uk/images/VAR...l/goldplug.png
Old 05-16-16, 11:25 AM
ukrbyk's Avatar
You may also look into this:
Oil Drain Plug | Drain Plug | Sump Plug
Old 05-16-16, 02:52 PM
A
It was leaking oil, but not nearly as much as it is now. He's a reasonable guy.
Old 05-16-16, 02:59 PM
A
I'll check the replacement plug out
Old 05-16-16, 07:40 PM
ukrbyk's Avatar
Prolly had crud built up stopping more leak. Now that plug was moved, loose threads resulted in more leak.
Oh, not to forget. Yellow teflon tape works very well on those.
