Car Remote Control
Old 06-19-16, 03:47 PM
WRDIY's Avatar
Received 40 Upvotes on 38 Posts
Car Remote Control
It will lock but it will not unlock for my Toyota 2003.
I have changed batteries but still the same issue. Is it the unlock button became defected or is there a fuse that I can change out?
Thanks
Old 06-19-16, 04:38 PM
C
Received 121 Upvotes on 97 Posts
There is a fuse for the electric locks but not separate fuses for lock and unlock, so it's not a fuse. Most likely the button on the key fob....that's the most commonly used button so is most likely to wear out.
Do the inside buttons work OK? Do you have a second fob you can try?
Old 06-19-16, 05:22 PM
WRDIY's Avatar
I don't know why I didn't think of this but good idea! Will try it and update later.
Thanks for the info on the fuse CarbideTipped.
Old 06-19-16, 05:34 PM
pugsl's Avatar
Received 76 Upvotes on 69 Posts
Lock button on my key fob has worn outca couple of times, found replacments in amazon for good prices
Old 06-19-16, 05:43 PM
WRDIY's Avatar
Thank you Pugsl. I will look for it on Amazon. I got a replacement for my wife's fob a few months ago at the Honda dealership. If I remember correctly, it was about $150.
Old 06-19-16, 09:59 PM
Received 3,479 Upvotes on 3,124 Posts
Based on the model of the 2003 Toyota.... you may be able to buy a generic replacement remote and program it yourself.
Some must be programmed by the dealer.
Old 06-20-16, 04:06 AM
pugsl's Avatar
Just went to amazon and looked up honda and toyota key fobs. They were between 8.00 and 60.00 $.
Old 06-20-16, 12:20 PM
WRDIY's Avatar
Thanks PJMax and PugsL!
How does the frequency of my current FOB gets transfer to this new one? Otherwise, this would be able to open all cars the same model.
https://www.amazon.com/KeylessOption.../dp/B0169FWW0U
Old 06-20-16, 01:21 PM
G
Received 2 Upvotes on 2 Posts
Compare it to a garage door opener.
The receiver in the car is programmed to recognize the signal from that particular opener.
Old 06-20-16, 01:34 PM
F
They should include instructions on programming the new remote to your car. I don't know what's involved for a Toyota, but for my Fords, it's a "rapidfire" sequence of flipping the key on and off in the ignition several times and then pushing a button on each remote.
Old 06-20-16, 02:24 PM
F
Do a Google using program (year, make, model of car) key fob (leave out the parentheses) as the search term. For the 2003 Honda it returns these results. https://www.google.com/?gws_rd=ssl#q...+honda+key+fob
Some cars cannot be programmed without special equipment. My 2009 Toyota Camry seems to be one although many of the google and YouTube results say it can. For these, look for an automotive locksmith to help as they are often less expensive than the dealer. On the other hand, some dealers may program the fob for free if you are having other work done on the car. You have to ask.
Old 06-20-16, 09:16 PM
What is the full model of the 2003 Toyota ??
Old 06-20-16, 09:30 PM
WRDIY's Avatar
Hi Goldstar, fShannon3, Furd and PJMax,
I found an extra fob that came with the car 13 years ago. Brand new. I thought that I might have to do a "rapidfire" trick that fShannon3 shared. Nope, it worked.
It worked. Just need to put in a new battery.
Thank you everyone!!!
