2003 Buick LeSabre check engine light
Old 09-03-16, 11:19 AM
P
Every time I fill up my tank or my gas runs low I run into the same Evap Code issue as a check engine light.
Between the 3/4 tank and 1/8 tank, the lights gone and I haven't had a single problem in the performance. But Smog time is coming, and I know this light is gonna show up on the reader.
Any ideas?
Old 09-03-16, 11:28 AM
Received 3,424 Upvotes on 3,070 Posts
Welcome to the forums.
You need to see what codes are set into memory and then work towards repairing them.
Old 09-03-16, 11:36 AM
P
P0440 and every time I look it up all I find from people is that I should replace the gas cap. I have replaced it several times, including one from GM and high performance and the current AC Delco on it.
Old 09-03-16, 12:19 PM
P0440 = Evaporative System Malfunction, Large Leak
When your vehicle is started there is a vacuum placed on the fuel vapor recovery system which includes the fuel tank for ten seconds. Then the vacuum valve is closed and a sensor monitors how fast the vacuum in the system decays or is lost. If it's too fast it knows there is a large leak and alerts you with a P0440 code. This test is only performed when the fuel level is between 15% - 85% of full.
The gas cap is only one cause of the problem. If you've replaced the cap.... that is not the problem.
With the age of your vehicle I'd guess you have a cracked or broken vacuum hose.
Another possible cause is a crack in the fill line or the vent line on the filler neck.
