Fast blinker on vehicle ?
Old 10-03-16, 01:50 PM
A
One of my blinker is going really fast and the light is NOT burned out. What could this be? Thanks.
Old 10-03-16, 01:53 PM
G
Received 2 Upvotes on 2 Posts
Check the other bulb. If the front is blinking fast, check the rear, while it is blinking & vice versa.
Old 10-03-16, 02:09 PM
Received 786 Upvotes on 689 Posts
I agree, fast blinking almost always indicates a burned out bulb, front or back. Not sure if the side markers can cause it also.
Old 10-03-16, 03:02 PM
XSleeper's Avatar
Received 1,813 Upvotes on 1,630 Posts
Those bulbs also have "high" and "low"... so check ALL parking lights (low) as well as brake/turn signals. (high)
Old 10-03-16, 06:54 PM
iceman681's Avatar
Received 5 Upvotes on 4 Posts
wrong bulb can cause this. or bad flasher
Old 10-03-16, 09:17 PM
Handyone's Avatar
I agree a wrong bulb could be the culprit.
Make sure no LED bulbs were used as substitutes.
Old 10-04-16, 05:41 AM
Received 24 Upvotes on 19 Posts
"One of my blinker is going really fast and the light is NOT burned out. What could this be?
The "What could this be?" question that I have is what make/year/model vehicle do you have ??
What light is not burned out?
Old 10-04-16, 02:52 PM
A
It's a 2014 Honda CR-V. No lights are burned out. Not brake lights. Not blinkers. Not running lights. Not parking. Nothing.
And then here's the thing. It's intermittent. It did it for a while and then stopped. Then it did it again for a couple of weeks straight. And then it stopped.
Could it be that one of the bulbs is just on the VERGE of burning out? It's really strange.
Old 10-04-16, 03:41 PM
Norm201's Avatar
Received 694 Upvotes on 617 Posts
I'd say it's the blinker relay. Needs replacement.
Old 10-04-16, 06:46 PM
Is it blinking fast (intermittently) on the left side or right side?
Old 10-05-16, 09:34 AM
A
The problem is on the left side.
It even changes during the middle of a turn (fast to regular or vise versa).
Old 10-05-16, 09:41 AM
I wonder if there is a wire with the insulation rubbing thru in column ?
Old 10-05-16, 11:55 AM
I would change both turn signal bulbs on the left side (front & rear).
I bet your problem will go away then.
Old 10-05-16, 02:27 PM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Could be a bad ground to one of the bulbs. When you hit a bump it may make a good connection for a while.
