2009 Pontiac g6, P2135 fail code
NOTE: OP is located in Mexico.
What is the most common cause of this fail code in this car? How can I fix it?
Hopefully, this will get you started:
https://www.obd-codes.com/p2135
Specifically for Pontiac: P2135 PONTIAC Throttle/Pedal Position Sensor/Switch 'A'/'B' Voltage Correlation
The automotive trouble code P2135 throttle/pedal position sensor/switch A/B voltage correlation refers to a problem related to the throttle's ability to open and close properly.
Part of the repair involves the question.... what was the car doing ?
You were driving, the car responded normally and the check engine light just popped up.
The car is running rough.
The accelerator pedal doesn't seem to be working properly.
