2003 camry 3.0L v6 rear driver side door wont open
Old 07-29-17, 08:58 PM
Received 1 Vote on 1 Post
Hello,
On 2003 v6 3.0 L camry driver side rear passenger door handle is broken and also inside handle is not able to open the door. I am trying to put new handle but can't open door. Any ideas on how to open the door? Please help
Thanks,
s2kfixit
Old 07-29-17, 09:08 PM
Would a slim jim work?
___________________
Old 07-29-17, 09:12 PM
Received 1,326 Votes on 1,225 Posts
The outside door handle doesn't work or is broken off the car ?
Do those rear doors have child safety locks ?
That's when the inside handles don't open the rear passenger doors.
Old 07-29-17, 09:13 PM
Hmm. I can try and see if that will work but since the handle and inside latch both are not connecting to open so i am wondering if slim jim will do the work
Old 07-29-17, 09:16 PM
If the door is not locked.... a slim jim will not help.
Old 07-29-17, 09:24 PM
Yes the car is not locked. I can't check if child safety lock is on . I can get inside the car but the inside latch is not opening the door so may be child safety lock is on. I cannot even open the door panel as its not opening. Any help will be appreciated.
Thanks,
S2K
Old 07-29-17, 10:03 PM
You didn't say if the outside handle was not working or broken.
If the handle is physically broken you may be able to work thru it to open the door.
Otherwise you may have to remove the rear seat to gain access to remove the interior door panel.
Old 07-30-17, 07:57 AM
ukrbyk's Avatar
Received 13 Votes on 10 Posts
slim jim is a dollar in a dollar store. It is always worth trying it. It is a mechanical device that pulls latch unlocked. Of course, you need to know how to operate it.
Safe to presume this is not power door locks?
Old 07-30-17, 08:53 AM
@Pete,
Yes the outside handle is broken and inside latch is not working. I am believing that it is due to child lock. I removed the seat but there no access to screws in bottom of door to remove screws.
@Ukrbyk,
let me try slim jim and see if that works. Yes It is a power door locks.
Thanks,
S2k
Old 07-30-17, 01:51 PM
ukrbyk's Avatar
Well if you have power door locks, then it should open from power door locks, safety or not. From a driver side main door lock switch at least. If it does not and you hear locks cycling, then something came off the lock mechanism and it will not unlatch.
Old 07-30-17, 01:57 PM
ukrbyk's Avatar
https://www.youtube.com/watch?v=1kPWfByAGR8
Check videos list to the right.
there are several various videos showing different approaches to the issue.
Old 07-30-17, 04:55 PM
As far as I know.... when the child safety lock is on..... the inside handle is not engaged..... only the outside one. Nothing to do with the actual door lock.
Old 10-11-17, 07:10 AM
the_tow_guy's Avatar
Received 62 Votes on 51 Posts
In some of the suggestions on using a slim jim, I see confusion between "lock" and "latch". As i read it, the door is unlocked but can't be opened.
Try this:
Check other side door to see the exact location of the child lock. Now use the slim jim, but not in the traditional way via the window slot, but rather from inside the back seat between door edge and door framing.
I checked wife's 09 and the little child lock switch appears to be fairly accessible to being slid in this manner. Don't have my slim jim handy to try it, but I think it'll work.
You may need to pre-bend the slim jim to fit in the gap.
Old 10-15-17, 10:49 AM
Soooo, did you get in?
