A 2002 Caravan Q
A 2002 Caravan Q
I have had to replace my brake light switch 3 times this year due to not being able to get the van out of park. The brake lights work just fine without any problems whatsoever.
Can't I remove the solenoid out of the steering column? If so how do I accomplish this?
Thank you.
Chuck
Thank you.
Chuck
Short answer - no. It is part of the safety devices built into vehicles and any advice given here to defeat a safety device will be deleted. Where are you getting the switches from? I'm not much on buying dealer OEM parts, but you may want to.
The solenoid looks like this...
2001 2002 DODGE GRAND CARAVAN SOLENOID SHIFT RELEASE P04680434AC OEM 1B1100 | eBay
The interlock is on pretty much all cars, a legacy of the unintended acceleration era of Audi, and also so that if you leave kids in a car while its idling they can't push the shift lever into gear. It is a pretty reasonable safety device, but the brake switch and solenoid can both fail. Sounds like your solenoid is on the verge of failing, so get it replaced, a good used one should suffice for the age of your car.
Hmmmmmmm...
I replaced my brake light switch a couple of months ago and it acted up again last month. When I replaced it it still didn't come out of park. Bear in mind I rarely use this vehicle, maybe 40 starts a month. I disconnected the battery ground cable, waited a minute, re-connected it and the solenoid worked properly.
It happened again today. So I just disconnected the battery, waited a couple of minutes, re-connected it and it worked properly. I didn't have to replace the brake light switch today.
So what's up?
Any thoughts??
Thank you.
Chuck
So what's up?
Any thoughts??
Thank you.
Chuck
A friend of mine had a similar problem, on a Ford. I told him to leave it in neutral until he got it fixed. I think that Shorty Long was right about those switches having an adjustment because that's what someone did. They moved the switch a hair & solved it.
