Pine Sap All Over The Car / The Question is How To Remove ??
Old 09-27-17, 06:47 AM
NorPlan1's Avatar
We have a large Pine Tree on the front lawn, it's a Hit & Miss from year to year and this year the Tree left Pine Sap droplets all over the Car.. We've tried using GooGone and a couple DIY solutions off Pinterest to No Avail... Thoughts Ideas Appreciated, Cheers Thanks
Old 09-27-17, 06:53 AM
XSleeper's Avatar
Received 1,975 Upvotes on 1,771 Posts
Have you tried turtle wax bug and tar remover?
Old 09-27-17, 07:29 AM
Received 874 Upvotes on 765 Posts
I've always used mineral spirits since I keep it on hand. Although it will remove any wax.
Old 09-27-17, 08:09 AM
Received 1,287 Upvotes on 1,225 Posts
Bug and tar remover would be my first choice as well.
Old 09-27-17, 08:30 AM
Marq1's Avatar
Received 1,211 Upvotes on 1,099 Posts
Bugs and tar are easy, I'm not sure what is used in the bug and tar removers, but I'd start off with some mild solvents like wax and grease remover before I got up to mineral sprits. You really never know what is in that stuff!
Old 09-27-17, 05:18 PM
F
Oil
Try some cooking oil, drop on the spot, let sit for a while then rub till it comes off with a microfiber cloth. Will not harm the paint. Rubbing alcohol is often recommended but can damage the paint/clear coat so would try that only as
a last resort.
Old 09-27-17, 06:11 PM
Received 24 Upvotes on 19 Posts
Chain saw bar oil -
apply it liberally to the bar and cut the tree down.
Use mineral spirits or WD-40 to remove the sap
Old 09-27-17, 08:31 PM
Gunguy45's Avatar
Super Moderator
Received 8 Upvotes on 8 Posts
Wonder how creamy peanut butter would work? It works for many things and keeps the oil right on the spot you want to soften.
Old 09-30-17, 07:12 AM
NorPlan1's Avatar
Pine. Sap Remover....
Thanks for the Comebacks.. Came across a YouTube Video, the Lad demonstrated 12 different possibilities, even some Name Brand Bug & Tar removers readily available at Canadian Tire and of course along with Peanut Butter & Mayonnaise.. 99% Proof Rubbing Alcohol did the trick with very little effort... Cheers Thanks.
