2000 Impala, intake manifold blew up while jumping car, why?
Old 12-30-17, 12:34 PM
K
My son was jump starting his car yesterday.
2000 Impala LS, 3.8L engine
Anyway, he says when he was jumping it that the intake manifold blew apart, at least a big chunk out of it. I am not there. He is in Missouri and I am in NC.
I am just looking for suggestions as to what may have caused this? He hit a deer a couple of weeks ago that did some damage to the left front corner of the car and he has been driving it since.
Just ideas is all I am looking for. Thanks
Old 12-30-17, 12:50 PM
Tolyn Ironhand's Avatar
Received 298 Votes on 258 Posts
My first guess would be he used starting fluid and the vapors in the manifold ignited.
Old 12-30-17, 01:20 PM
A
Received 25 Votes on 24 Posts
pretty much had to back fire through the intake and since there plastic not as strong as a aluminum manifold would of been, not a very common problem but have read of it happening before.
https://www.youtube.com/watch?v=SiqV_ifh9G0
Old 12-30-17, 05:58 PM
ukrbyk's Avatar
Received 14 Votes on 11 Posts
His car timing is off. Hence, it wouldn't start. Then, it backfired into intake. Most likely timing belt or chain related.
Old 12-31-17, 11:57 AM
B
Received 106 Votes on 93 Posts
The scenario in each response is reasonable for a plastic manifold to explode. However you need to get more info from your son to understand his experience. A couple I can think of; Why was he jumpering the vehicle? Did he connect the negative jumper last and make it away from the battery? Was he using a starter fluid?
