1996 mecury grand marquis no flasher brake and turn signals
I have a 1996 mecury grand Marquis and the turn flasher and brake lights quit working and this is what I did to fix it ( the control module went out in my car) I ran a wire from the brake light switch the lower wire is the hot wire for the switch take the other end of the wire and find a fuse that is live all the time put the wire on one side of the fuse so it can still blow if it has to I have had no problems with my brakes and flashers and turn signals since I did this and it has been six months it is cheaper than spending 300 dollars for the control module
Welcome to the forums.
It sounds like the circuit that would normally supply the brakes and flashers failed.
It could be as simple as a fuse that is bad that looks good.
