New Dual Halo Projector replacement headlights
Old 12-26-18, 06:12 PM
Received 1 Upvote on 1 Post
Hello Experts,
Need some help installing the Toyota Camry 2003 LE 3.0L V6 Dual Halo Ring Projector Replacement Headlights Front Lamps Left/Right Pair. i bought it from amazon but now am confused with wiring.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
This is what i bought from amazon.
Any ideas.?
Thanks,
S2k
Old 12-26-18, 07:42 PM
Received 4,119 Upvotes on 3,699 Posts
Yes and did you read this in the description.....
No Installation Guide or Instructions Included, Professional Installation is Highly Recommended
You're going to need to post pictures as there is no way we can guess what you have there for wiring or connectors that don't match How-to-insert-pictures
Old 12-27-18, 12:23 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
***2002-2004 Models may need Wiring Modification to Install***
States that your 2003 model will need some wiring modifications!
One person commented:
The Instructions are poorly written and while installing these headlights myself, I had to go through a lot of trial and error which was frustrating. Nevertheless, you have to use quick connects to splice the Halo lights and the LED light wires together. After that, splice the same LED wires (positive and negative) into the parking lights wires (Positive and Negative), everything else should be a breeze. Make sure to use a Multi-meter to figure out the polarity of the wires.
I think I would have just upgraded the bulbs and saved the headache!
