97 Lesabre low pedal after rear drum replacement
Received 0 Votes
Hey guys, hoping maybe someone can lead me in the right direction here.
1997 Buick Lesabre- just replaced the rear brakes. Did both wheel cylinders, brake shoes, drums, adjusters hardware. Even after bleeding both rear brakes repeatedly, when stopping the brake pedal goes pretty far down. It was fine before touching the rear brakes. I did not bleed the fronts, only the rears.
I have read that since the front and rear brake systems are separate, bleeding just the rears should be ok. Is this wrong? Is there something else I should try? Any help appreciated!
Did you adjust the brakes? The self adjusters will tighten up the rear brakes but it can take awhile. Generally the rear brakes are separate from the front but on my jeep it's diagonal [1front and 1 rear]
Received 0 Votes
If the master cylinder reservoir has separate zones for the front and rear, then you should be alright by just bleeding the rear. If it's just one pool of brake fluid for the whole car, then you need to bleed the front and rear. Start from the furthest bleeder away from the master cylinder (usually passenger rear > driver rear > passenger front > driver front)
This is what came up when I searched for a 97 LeSabre master cylinder:
Looks like it's a shared reservoir for both the front and back. In theory, if you kept fluid in the reservoir the entire time and didn't let it go dry, no air should have made it's way back into the reservoir. However, If perhaps your timing was off with pressing down the pedal/your helper opening and closing the valve (or if you used a bleeder bottle and missed it sucking in air) then it would introduce air into the entire system. I recommend bleeding the entire system and seeing what you get. Make sure you or your helper watches the line until there are no more bubbles, and keep the reservoir full.
If your pedal is still soft afterwards, I would pull the rear drums and take a look at the wheel cylinders. Are they wet? Is the line wet? Did either of the seals on each end of the cylinder come out? Did the pins become unseated?
Good luck!
Good luck!
Normally, lines are crossed front front to rear. So it's passenger front and driver rear and driver front and passenger rear. reason being if one line is damaged, you still have even braking force applied to BOTH vehicle sides. It does not make any sense to have rear and front separate.
So normally, when you bleed, you want to do all 4, starting with the farthermost one from the master, which is passenger rear>driver rear>passenger front>driver front.
Back when drum brakes were on all 4, the brakes weren't separated. When they started putting disks on the front they separated the front and the back. No expert but I think the diagonal thing came about when they went to all 4 disk brakes.
Received 0 Votes
After bleeding the brakes again, I took a look at the rear brakes. Way too loose. The right rear adjuster some how adjusted it self back in keeping everything loose. I readjusted both rear brakes out a bit and the pedal feels great! Not sure why the adjuster on the right side had went all the way back in by itself? Dont they normally adjust out?
Normally - my favorite word - you manually adjust adjuster. It should stay there thereafter. If it "self adjusted" you messed something up during the job. Those are VERY simple mechanical things that don't get mind of their own.
