2009 Matrix: MAINT REQD flashing, ... What needs to be done?
Old 07-08-19, 02:32 PM
PineCone's Avatar
Hello:
This morning, I noticed 'MAIN REOR' flashing upon started an engine. The car is '2009 MATRIC' which running REALLY well without any issues attached.
The flashing/warning sign appears to me I need to take it to the shop?
Thanks for any help in advance.
Old 07-08-19, 02:34 PM
Received 1,321 Votes on 1,221 Posts
What is a 2009 MATRIC ??
Old 07-08-19, 02:37 PM
Received 360 Votes on 317 Posts
If the check engine light is flashing that normally means a serious issue. I'd at least hook up a code reader to see what it says. Many parts stores do that for free.
Like Pete said - what is a Matric??
Old 07-08-19, 02:40 PM
XSleeper's Avatar
Received 779 Votes on 718 Posts
Matric = Matrix.
And I assume main reor = maintenence required.
I love autocorrect.
Old 07-08-19, 02:42 PM
Toyota Matrix and the MAINT RQRD = maintenance required.
Reset maint rqrd video
PineCone's Avatar
Sorry, ..... '2009 Corolla MATRIX' which runs really well with low mileage. I'd plan to part-store for hooking-up. Seems no need to go to the shop which may charge me a lot.
Old 07-08-19, 03:16 PM
F
Received 36 Votes on 28 Posts
On my 2009 Camry it means it is time to change the oil. I think 5000 miles since last reset. I forget exact reset procedure but I found it on a YouTube via a Google search.
Old 07-09-19, 05:08 AM
the_tow_guy's Avatar
Received 62 Votes on 51 Posts
Maint req'd, as Furd says, normally means oil change. As I recall, the message comes on when it's time for an oil change and FLASHES if you ignore it for more than a set number of miles, in other words oil change NOW.
Old 07-09-19, 07:10 AM
ukrbyk's Avatar
Received 12 Votes on 9 Posts
Well, on my Toyotas it went from Maintenance Required Soon>Maintenance Required> to being unable to get out of that menu, as it will cover other vehicle information on display. THEN you MUST do maintenance.
Probably just oil. Honda tosses a specific maintenance item code on display, Toyota does not. Normal for Toyota is 5000 mile interval.
OP, change oil. No need to go to parts store for "hook up".
Old 07-09-19, 07:52 PM
Received 10 Votes on 7 Posts
What does the owners manual say about the flashing light ??....
Old 07-10-19, 06:11 AM
Here it is officially:
Illuminates for about 3 seconds
and then flashes for
about 15 seconds approximately
4500 miles (7200
km) after the engine oil is
changed: Indicates that the
engine oil is scheduled to be
changed.
Comes on and remains on if
the distance driven exceeds
5000 miles (8000 km): Indicates
that the engine oil
should be changed.
