2001 ford explorer, wont shift easily into park or drive anymore
Received 0 Votes
About two days ago I started to notice that my vehicle when I try to put it into drive after you're pulling out of a parking spot stayed in neutral so I tried to put it back into park and it wouldn't go back into park without me trying to slam my shifter all the way up so I check the transmission fluid which was fine then I disconnect my battery for five minutes to see if that would reset the computer inside and I did nothing there is no check engine light on no nothing no fluids are low I'm not too sure where to check for my adjuster cable if there is one or how to check my transmission cable in general. Someone please help
Common problem with the early explorer, lots of forum and video posts available!
https://www.explorerforum.com/forums...-cable.419545/
