Replacing an Infiniti thermostat
Old 10-22-19, 05:44 PM
T
infiniti fx 35 2008 is running hot. i was thinking it's the thermasta
Old 10-23-19, 09:24 AM
T
Received 19 Votes on 15 Posts
Thermostats are designed to run cold as they age and fail. When was the last time the cooling system was serviced? Is there coolant in the overflow and is the radiator full? Are the cooling fans working and is the front of the radiator clean so air can flow through? Do you get good heat in the vehicle?
