View Poll Results: Was the article helpful?
Yes
100.00%
No
0
0%
Voters: 1. You may not vote on this poll
How to permanently disable engine auto stop?
Old 04-20-23, 07:37 AM
B
I looked up several YouTube videos on how to disable the auto-top feature in the 2018 Chevy Equinox (put it in L, + sign up to sixth gear, then back to drive). Which does work, but only for a time. It reverts back after you return to your vehicle. Is there a way to disable this permanently?
Old 04-20-23, 08:05 AM
Shadeladie's Avatar
Super Moderator
Received 393 Upvotes on 321 Posts
Nope. I don't even notice it on mine any more. Doesn't affect anything as far as I can tell. Why does it bother you? Just curious.
Old 04-20-23, 08:48 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Only by the temp method you identified!
Old 04-20-23, 11:45 AM
Received 23 Upvotes on 21 Posts
Curious if there are any statistics on how long a starter lasts on these auto shut off cars. And, how much they cost to replace. Do the batteries also need replacing sooner?
Old 04-20-23, 12:23 PM
Received 840 Upvotes on 737 Posts
It's my understanding that they take a more expensive battery. don't know about the starter.
A friend of mine has a Ford Escape and he had that feature turned off by the dealer.
Old 04-21-23, 05:24 AM
Received 24 Upvotes on 19 Posts
It should be optional - not mandatory. Too much government control ... save on fuel ?
Try cutting back on this https://www.flightradar24.com/44.23,-59.58/4
and this https://www.marinetraffic.com/en/ais...ry:16.8/zoom:3
Old 04-21-23, 06:36 AM
Shadeladie's Avatar
Super Moderator
You can turn it off and on in new models, I believe.
Let's not turn this into a political thing or I'll have to close the thread.
Regarding starters, from what I've read, doesn't affect them any because it's a different kind of engine.
Old 04-21-23, 06:49 AM
Received 6 Upvotes on 4 Posts
I too find that feature somewhat irritating!lol While I do manually turn it off, I get frustrated with myself when I forget to turn it off again once I've shut the vehicle off. Doesn't bother the hubby so much (but this is more my vehicle than his--'21 Ford Bronco Sport). But then with so many things now-a-days that are becoming supposedly newer and more modernized, guess I'll just have to roll with the times! :-)
Old 04-21-23, 07:02 AM
A
Received 119 Upvotes on 103 Posts
dealer may be able to turn it off with a reprogram of the computer not sure its really offered but guess you could find out with a phone call to the service department.
would imagine the starter motor will need replaced sooner since it is being used a lot more frequently.
Old 04-21-23, 08:04 AM
P
Received 19 Upvotes on 18 Posts
check with a company called Autostopeliminator.com. they offer something for several GM and GMC vehicles but did not see your vehicle listed. not to say what they have won't work for you so call and ask.
- Peter
Old 04-22-23, 03:53 PM
A
Received 4 Upvotes on 2 Posts
It doesn't bother me, but I've had it over 20 years now on various hybrids. On conventional cars, the starter is beefed so it should last just as long. What's not to like about it? Or are you one of those folks I see at a stop light that move up one foot every 20 seconds even when the other cars are standing still?
Old 05-09-23, 11:34 AM
B
Update:
I ended up buying the start/stop disable cable and installing it. Was very easy (just zip tied it down). But I had to remove it, after my wife said she lost power when trying to drive it over a bumpy rail road tracks. Was almost like it wasn't getting gas/power when hitting the pedal. Removed it again, and everything is fine now. Any thoughts on that? Otherwise I guess I'll just have to live with it.
