Need to put a new bracket on a 2018 Hyundai. Car has never had a front bracket. Per the photos, the bumper is all plastic and the universal tag instructions say to drill holes and use the provided screws (see photo). I'm worried that the plastic won't hold and the screws will tear the holes. There are a couple of places where there are small indents - I think for screws. But the plastic there is even thinner than the bumper.
Any suggestions? I don't want to go the tow bar mount route.
It'll be very strong and very secure if you follow this method. I've done it a number of times and I'm very particular about it - OCD you might say!
I suggest drilling small hole in the indents of the plastic where the bracket is designed to be mounted. Then screw the screws into the small holes you drilled in the plastic plastic a little bit (maybe a enough to catch a couple threads), then back them back out. Then, you can put the screws in the license plate bracket holes and it'll be easy to screw it into the pre-drilled and slightly pre-threaded holes you made.
Don't make the mistake of trying to handle the screws and the bracket and the screwdriver all at once while trying to screw the screws in the bracket holes into the indents with a screw driver or drill. It's far easier to pre-drill a small diameter hole in the indents and pre-thread the holes a little bit with the screws. That bracket will snug up very tight and secure. It ain't coming loose!
Thanks all! beelzebob - that's a universal bracket I bought at the autoparts store. I did find a factory bracket - bought it and it makes absolutely no sense to me - the holes on the bracket don't match anything on the car:
I did find a factory bracket - bought it and it makes absolutely no sense to me - the holes on the bracket don't match anything on the car.
I suspect you somehow got another model's front license plate bracket. I've heard about that happening quite often. Oftentimes cars will have different models or some models get frontend facelifts in the middle of model generations, so you need to be sure to get the front license plate bracket for your exact VIN. The dealership that handles your car's brand can help with that. Sometimes trying to pick the correct front license plate bracket on an Internet site doesn't get you the right one...
And, yes sometimes when first looking at a license plate frame that is indeed the correct one - it just doesn't look quite right to be the correct one, especially if it is to be screwed into the plastic behind a car's grill.
Lastly, 'universal' front license plate brackets rarely work out well. Those 'universal' mount front license plate brackets are typically designed to screw into the front bumper, which messes up the looks of the bumper if it's ever removed. I think it's always best to get the front license plate bracket that is actually designed for the car...
Reason: orthography
Ok - I'll stop after this. I obviously failed with my comment, unless you guys are pulling my leg, in which case the jokes on me -lol. But the word "sardonic" might clarify my comment (post #7!
I am trying to turn off the light for the[b] tire pressure[/b]. I have read the manual but I guess I keep on missing the part on how to turn off the light. If I go to YouTube, I am told to push a button or push the three buttons on the right of the steering wheel. Any thoughts on how to turn off the D_ M LIGHTS ON THE DASH? I did it I think once before and wrote it down but most of lost it.[img]https://cimg0.ibsrv.net/gimg/www.doityourselft.com-vbulletin/400x618/aol_mail_t111_d662fb22bd03338ed8e2afe8123b9628670c835c.jpg[/img]
[img]https://cimg5.ibsrv.net/gimg/www.doityourselft.com-vbulletin/440x680/aol_mail_t222_2fd69ef699b7f11b3ac02aeeeb015118b2c078a0.jpg[/img]
. MY CRV does not have any of these. Below I have 2 pictures to show my crv is not like the ones on YouTube. I called Honda and was told to look on youtube.Read More
I see youtube video showing how old car batteries (lead acid) can be rejuvenated by passing a large current through and causing the acid to boil. I don't plan on doing this because I don't have the equipment and also it sounds slightly dangerous. But I'm curious.
If this works, why isn't anyone offering battery rejuvenation service, or selling rejuvenated batteries?Read More
