Would using drywall sheet paper over tape work better for this repair ?
The repair is in between two shelves in a closet. Would the damage area have to be cut and meshed over or can you use the drywall sheet paper as tape. The damage section seems to be holding out fine the damage area does not go through to to the other side.
IF it is only the surface paper, cut a "football" around the offending area, peel the paper from the football and skim coat it with drywall compound.
