Repair drywall tape
Old 10-03-17, 02:12 AM
C
Repair drywall tape
Size:  97.7 KBon one corner of one of my walls, the part that sticks out. it looks like there was some drywall tape placed there and there is a little area that has come loose. should i just paint over it or put some spakle over it first
Old 10-03-17, 02:16 AM
Received 785 Upvotes on 688 Posts
Hard to say without seeing it. If it will lay back down you'd apply joint compound under the tape to 'glue' it back down and then apply more j/c over it once it has dried. It might also require texture. If the tape won't lay back down you'd cut out the offending portion and add new tape.
Old 10-03-17, 03:03 AM
C
Here is another photo...............................................
Old 10-03-17, 03:23 AM
Is there loose tape or is it just the joint where the corner bead has cracked?
Old 10-03-17, 07:05 AM
Received 1,231 Upvotes on 1,179 Posts
Looks like corner bead and not tape to me.
FWIW, the material you would want to use is joint compound, not spackle.
Old 10-04-17, 03:54 AM
Marq1's Avatar
Received 1,209 Upvotes on 1,098 Posts
Agree, looks like a corner bead.
Needs to be re nailed down then patched.
