Trailer wobbles
Trailer wobbles
I bought an old pop-up camper that I turned into a concession trailer. When I bought it I had to put different size tires on it to get it home. After finishing the rebuild I took it out for a test drive and the whole thing wobbles, not sways but wobbles. Tires are brand new, most of the weight is in the back but I have weighted down the front to even it out. Rims do not look bent. Any suggestions on what could be causing it to wobble? Thanks
I just can not imagine a light weight, single axle pop up ever working as a concession trailer.
There built with the thinnest material possible to save weight, tiny springs thin axles.
I had the frame on my Rockwood pop up break right off just going over a bump in the road where they were just repaving a road.
After verifying trailer axle is secure to the trailer frame, verify trailer axle is square to the center line of the trailer frame (line from center of trailer hitch to center of last trailer frame cross member at the rear. Verify tires are the same distance from the center line and the same distance from the hitch. Also verify the concession box is secured to the trailer frame. Good luck.
Originally Posted by joecaption
I just can not imagine a light weight, single axle pop up ever working as a concession trailer...
