first time rear brake replacement
Hello
I changed the rear pads, rotors and calipers in 2000 silverado. This is the first time I ever did this task myself/ DIY. Everything seems OK after the repair, no brake lights, no squeaking, etc. The pedal feels different but I assume that will change once its breaks in. It was a pleasure to drive without grinding noises for the first time in awhile.
Anyway, how do I truly know that the breaks are working? Since the front brakes do most of the works, I would be stopping even if the backs werent working. I did touch the new rotors after my test drive and they were hot.... thats the only test I can think of!! I didnt think to depress the pedal with the tires off and still jacked up.... I put the tires on immediately and fired it up!
Thanks
Thanks
Welcome to the forums.
You changed the calipers too ?
That would mean you had to bleed the air out of the rear lines and calipers.
Allow plenty of fluid to flush thru the lines. On an older vehicle it's important to purge the lines of old fluid and water.
The calipers got changed, the pistons were frozen and the bleeders were stripped.
I did not bleed them though, I quickly removed the brake line and reattached. Barely any fluid came out from the line as I had the cap on the cylinder.
I planned to do a complete flush at a later day and needed to get back on the road.
Am I asking for trouble?
Um, if I'm understanding you correctly, you bought new calipers (that are empty of fluid) and attached them really quickly to your brake lines (after you dc'd your old calipers)?
My guess then you had to pump the brakes a lot and add fluid in order to fill the calipers and compress the air that is trapped in them. This should result in a very mushy pedal and significant loss of braking power. It should be very noticeable. You should have a solid pedal feeling.
Very unsafe. On some braking systems, the compressed air will push fluid back into the lines which will result in no brakes at a most inopportune time!
I'm surprised you didn't say to yourself something is wrong. Unless there is something you left out of your operation?
Edit: Rotors will get hot to the touch just by friction from the turning wheel. Hot rotors to the touch mean very little. Our tolerance for heat is very low compared the heat range of a rotor.
I was a brake mechanic for many years, The easiest way I found to bleed brakes was to open the bleed screw and gravity bleed till clean fluid came out Take top off MC and a must is to keep adding fluid . DO NOT LET MC GET EMPTY It will take 5 to 10 minutes at each wheel. Even if you did not work on front bleed them also. The last thing is to close all bleed screws and pump brakes. Go around each wheel and open bleed screw. you will see a air bubble come out.
Very dangerous to drive without bleeding.
Im fortunate you reminded me. I bled them this morning and their is a significant difference in firmness. duh! Now which one of you want to go on a ride on the expressway with me?
FWIW the only way I've ever been able to successfully change/flush fluid is by using a Motive bleeder.
No need to deal with the MC, just hook it up to your reservoir and pump fluid through.
Anytime the brake lines have been open, even briefly, air has entered the system and the only way to get it out was the Motive bleeder.
