Propane heater in camper
Old 11-04-18, 09:46 AM
1
Hello, I just purchased a new to me camper, it has a furnace that works off electric and gas, I need help figuring out why its not working!
Its a little bitty thing and I cant imagine its rocket science to repair but like anything else if you dont know what you are doing its not easy.
To add wood to the fire I am electronically challenged ( and I dont mean kinda )
I can prob bring it to someone and pay 2-400 to have it repaired or I can buy a new one for about the same price but I am not interested in that, I want to repair what I have and have the satisfaction of doing so.
Ive tried RV forums and I cant get any bites from anyone that willing to get down to the nitty gritty and tell me do this and report back, now do this and report back and now do this and you get my point.
I believe I have wiring schematics, I believe I have the information needed to fix the thing I just dont know how to read it or where to start.
Is there anyone here willing to help?
Tomm Monday and I go back to work so this might be a slow process, I am in no rush though. I can put a little bit into it every night and all weekends.
I know its alot to ask and Im hoping to find someone that knows and isnt just trying to be kind and kinda guessing cause I dont want to damage the unit further.
Thanks for any consideration
Old 11-04-18, 09:51 AM
1
Here are some pictures of the unit, maybe they will help.
It is an Atwwod Hydro flame FA 7920
https://postimg.cc/187DY4wG
https://postimg.cc/TpGjKzTD
https://postimg.cc/8sgRntZw
I can and will add any picture necessary
Id rather not remove unit from RV cause I hate to break the propane line and then deal with a leak I didnt have before
Old 11-04-18, 10:04 AM
1
Old 11-04-18, 10:11 AM
1
Here is a link to service manual
http://bryantrv.com/docs2/docs/hydroflameold2.pdf
Old 11-04-18, 10:24 AM
Received 3,992 Upvotes on 3,583 Posts
Welcome to the forums. ............ (thread moved to the camper forum)
What is the full model number ?
That runs on 12vdc and propane.
Is it doing anything at all ?
Did you check for 12vDC to it ?
Manual
Old 11-04-18, 11:03 AM
1
I believe thats all there is.
When I turn the thermostat all the way up and then switch it to on I hear a very faint single click down in the unit, same thing when I switch it off,
Nothing else happens that I am aware of
Old 11-04-18, 11:44 AM
W
Received 63 Upvotes on 55 Posts
Propane supply must be on. Sometimes, it takes a short time for gas to reach the furnace.
Old 11-05-18, 06:59 AM
G
Received 2 Upvotes on 2 Posts
Does your unit have spark ignition or a standing pilot? The linked manual describes both. If the pilot isn't lit the gas valve won't open so the little "click" of the call for heat is all you'll hear.
The linked manual is pretty good at describing the sequence of operation but the owners manual that came with the camper would have the info on what type/how to light the pilot.
Old 11-05-18, 05:28 PM
The FA-7920D is a direct spark ignition. It's lit automatically.
The FA-7920P is a manual piezo spark ignition with pilot light.
So if you have the pilot version.... it needs to be lit.
If you have the direct spark model.... the blower needs to start running before the unit will light.
