Turn signal switch
Old 12-08-18, 04:17 PM
D
Received 1 Upvote on 1 Post
Turn signal switch
I have a 91 P30 step van, based on a chevy truck. The ability to self-cancel the turn signal from a left turn has stopped working. Right turn still self-cancels. Is the self -cancel built into the turn signal mechanism or is it a cam inside the steering shaft. Thanks,
Old 12-08-18, 04:33 PM
Received 3,951 Upvotes on 3,544 Posts
Both...... a cam on the center hub hits the mechanism on the directional control. The directional control uses a spring to cancel each side and it may have broken. You'll need to pull the wheel off to get to the problem area.
Old 12-09-18, 06:44 PM
D
Bummer on pulling the wheel. Thanks.
Old 12-09-18, 07:17 PM
Yeah..... there's nothing you can do without pulling it. All the guts are right below it.
Here's a great link on steering column work. It may not be identical to yours but it'll be close.
Link contents by owner Oliver Scholz©...... Steering column repair
Old 12-10-18, 04:15 AM
Norm201's Avatar
Received 721 Upvotes on 640 Posts
Common problem. I had two Chevy vans and it happened on both.
