Thickness on Emerg. Brake Shoe Thickness
Old 08-25-19, 05:52 AM
biketrax's Avatar
Received 3 Upvotes on 3 Posts
I am trying to find out when you should replace the E brake shoes on my truck. I have about an 1/8" thk left on both sides and I hardly ever use them. I am doing the rotors and pads. So I was thinking of doing the shoes also but I dont feel I will wear them out?
It would be nice to know what the spec call for, I dont believe my books indicate any.
Old 08-25-19, 08:04 AM
Received 125 Upvotes on 110 Posts
Since there's no location in your profile it's anyone's guess what's allowed in your area.
In VA it's 2/32, not sure why they write it that way, it should be 1/16th.
Old 08-25-19, 10:50 AM
B
Received 235 Upvotes on 208 Posts
If you were paying someone to do the rotors. I am sure you would choose to have the e-brake shoes replaced as labor has to be the biggest part of the bill. If it was me, I would replace the shoes.
Old 08-25-19, 02:15 PM
Marq1's Avatar
Received 1,104 Upvotes on 1,004 Posts
Honestly I dont think you ever need to change them.
First off they are parking brake, they engage when the vehicle is stopped so technically there is no wear on the pads/shoes.
Second, as someone noted, they dont get a lot of use, so if there is any pad left, and they dont have much to start with your good!
Old 08-26-19, 04:34 AM
GregH's Avatar
Super Moderator
Received 66 Upvotes on 61 Posts
I might add that it is true that they will not wear out when used properly but a bad cable or not being fully released could destroy them in one trip.
Old 08-26-19, 05:59 PM
pugsl's Avatar
Received 76 Upvotes on 69 Posts
In all the years I worked as a brake mechanic I can't remember ever changing parking brake shoes.
Old 08-27-19, 03:51 AM
the_tow_guy's Avatar
Received 176 Upvotes on 138 Posts
Replaced the p-brake shoes (driveshaft-mounted) on my wrecker few years back....at about 600,000 miles on the odo.
Old 09-02-19, 06:41 AM
biketrax's Avatar
Thanks Guy! You all confirmed my thoughts! Only remember changing one pair in my life at least on cars! That pair of shoes were used improperly and destroyed.
Cheers for input!
