Gas Log Kit Piping
Old 02-11-16, 06:11 AM
T
Gas Log Kit Piping
Hello
Considering a gas log set for my home (converting a wood burning fireplace) This would be a direct vent type of kit. I am looking for a way to run the gas piping into the firebox. I am unable to come in from the side of the firebox, nor from the back, however there is an ash clean-out directly under the grate that holds the wood. would it be acceptable to use this chase-way to run my pipe?
Thanks
Kevn
Old 02-11-16, 12:07 PM
F
I would ask the LOCAL inspector. You ARE getting a permit and inspections, correct?
Old 02-13-16, 04:57 PM
T
Yes it will get a permits and inspection. I just want to understand my options before moving forward thank you kevin
Old 02-14-16, 07:20 AM
Z
Received 416 Upvotes on 369 Posts
Also make sure the insert you purchase allows the gas line to come in from the bottom center. I believe many (all?) do.
