Dryer Vent
Old 03-12-16, 06:03 AM
F
Dryer Vent
Does anyone know where to a dryer vent that fits INSIDE the "4 duct? All I find are one's that the collar fit outside the duct. I bought one before at Lowe's but now all the have is outside fit. Thanks.
Old 03-12-16, 06:16 AM
Tolyn Ironhand's Avatar
Received 672 Upvotes on 570 Posts
The crimped end will fit on the inside. The straight end fits on the outside.
If you don't have a crimped end you can make one with these: Klein Tools 5-Blade Crimper-86550 - The Home Depot
W
Received 60 Upvotes on 52 Posts
Old 03-12-16, 07:08 AM
C
Received 107 Upvotes on 86 Posts
They are made that way because if the vent fits inside the duct, it will create a lip in the pipe that will collect lint and eventually clog and/or become a fire hazard. Dryer vents should always be assembled so the crimped ends of all the joints face away from the dryer and toward the wall cap. You would be better off enlarging the hole (if that's the problem) so you can assemble it in the proper direction.
Old 03-12-16, 03:40 PM
Received 125 Upvotes on 110 Posts
Odd question.
Can you add more info or at least a picture why you need to do it that way?
Old 03-12-16, 05:21 PM
F
I have vinyl siding. When I remove the cracked old one there is your duct. It comes through the 2x6 framing. Perfect fit so there is no way to put a vent with collar or any ducting on the outside of the duct. Just like if you were to drill a "4 hole in a 2x6 the duct would fit through the 2x6 but there would be no way to fit a dryer vent collar on the outside. Killer is I have replaced this before. Can't find one that fits the ID now.
Old 03-13-16, 05:12 AM
Any holes drilled for a dryer vent should have been 4-1/4 not 4", that's you main issue.
Old 03-13-16, 05:26 AM
pugsl's Avatar
Received 76 Upvotes on 69 Posts
You can try this or buy apro tool but they cost $
Duct-crimping in a pinch - Fine Homebuilding Tip
Old 03-26-16, 04:21 PM
F
Ok. So I se I'm going to have to modify this and enlarge the hole. What would be the best way to enlarge my 4" hole? I think a sawzall would be difficult up against the vinyl siding. Thanks.
Old 03-26-16, 04:25 PM
Norm201's Avatar
Received 668 Upvotes on 591 Posts
Send us pic so we can get a better idea of what you have.
Old 03-26-16, 06:24 PM
Received 3,419 Upvotes on 3,065 Posts
A picture would help.... http://www.doityourself.com/forum/el...-pictures.html
If I understand you correctly.... you just want to replace the outside hood. Those hoods come with a piece of 4" metal duct.....usually pretty poorly attached. Remove that duct and slide the new hood over the existing duct. I've done that several times with the quality vent hoods from the depot.
Old 03-27-16, 11:55 AM
W
Vent
You want the hood to fit the outside of the duct coming from inside the house. Otherwise, you will have an edge of the hood facing upstream which will catch lint coming out of the duct.
